First post and still very much learning about diagnostics and programming etc with Forscan.
Van keeps failing the learns (reset prv counter, pump learn, pilot learn) midway through the pilot learns, so I am trying to do a pcm update.
All I am able to find is Module configuration (as built format)
I assume this is the format the vehicle was originally programmed with when new?
I am using Forscan 'offline' and maybe that is where the problem is?
ie: do I need to have a Wifi connection to access the latest pcm updates, or should I be able to do this 'offline'?
I know this van has NOT had any updates since at least 2010/11.
All help appreciated
