Hi guys!
I have RV on Ford transit mk6 2.2TDCi 2006- chassis. I would like to do the pilot learning after I got the first software upgrade, to prevent burning of the pistons. The stuck EGR (not with carbon deposits, only electricaly worn out) does not allow it. So I bought OEN matching one and built-in myself the new EGR on eBay 50EUR, which I find to be electronic (contains Hall's sensor and magnet), while the first and original (now stuck) EGR from Ford was electric (contains a potentiometer with sliding brushes). When I started the engine, no light on the dashboard appeared nor now nor earlier. I can drive normally. Is it possible to make only an EGR test before the start of the pilot learning of the engine? Is it true that if the pilot learning of the engine fails, there is no way back and the car remains a not drivable? Is it possible that garage would artificially set me up a failed pilot learning to require greater repairs? Thanks.
