Hi please help. I have been reading through all posts but can’t seem to find where to post.
I have a 2008 (58) 2.2 fwd ford transit with about 240k on clock. Owned the van for about 3 years and serviced yearly. Unsure what previous service was. Recently had a change of oil, fuel and air filter. I had the van for around 1 year with a egr fault on. Egr valve bolts had been snapped and no one would work on it. Driving on motorway a few weeks ago doing a 69 mile journey. Van seemed like it had less power but got there ok, engine temps all ok. On the way home the van just died on motorway, luckily I managed to get up and onto a grass verge as no hard shoulder. Opened bonnet and turbo was smoking and smoke coming up it to air box. Left for half hour and tried to start with no joy. Towed the van home and left over night, tried to start next morning and it’s started but running rough. I found someone who would do the work, removed turbo and replaced the cartridge. While we where there we ended up getting egr, pipes and manifold off replaced egr and cleaned all the pipes. Remove radiator and cleaned all pipes, cleaned boost pipes (quite oily) got everything fixed back up and it was going well. Driving it for a few months now local and maybe 20mile trips at the most but mainly 5-6 mile. Drove good the only thing I noticed was temp was good good but engine felt hotter than normal and it’s smelt a bit like radiator water but everything was good, no loss of water and still a strong clean coolant mix. I noticed injector was leaking and seemed like oil/fuel and water sat in the housing around injector, it would bubble when engine runs. Oik warning light flashing intermittent (mainly when off the gas breaking) only briefly. I noticed it after the new egr and turbo was fitted. Also when removing dip stick and oil filler cap with engine running smoke would puff out but it seemed to stop doing it after a few weeks. Van in use daily no real problem until I do the same 69 mile trip on the same road the van suddenly starts loosing speed fast (unlike before it was more of a instant cut out) this time the van was driving but loosing speed and power fast (I was doing around 70mph) it got to about 50 I noticed smoke from the rear and seen hard shoulder was coming to an end so I made sensible choice of pulling in, soon as I slowed to about 10mph van cut out and egnition lights came on. Opened bonnet, engine very hot but plenty of water, all pipes seemed hot so circulation seemed ok. Turbo wasn’t smoking this time. It wouldn’t start and still won’t. Friend thinks piston rings or seals. It tries to turn over but now battery flat. Iv had injector seals done in the past and fuel rail and a few other bits. Something seems to be blowing injector seals very end on right side was worse one and end left. I have removed the injectors got all copper washers and removed rocker cover to replace these gaskets. I don’t know much about engines really, read everytning in these posts, I know the basics. Under the rocker cover all I think as valve arms? Well they all seem nice and tight but 1 in intake side is very loose and wobbely (i recognis the sound of the tapping, another are slightly loose and one on outlet side is very loose. I don’t know if I should just putnrocker cover seals cover back on, new injector seals and copper washers and put it all back together and see what happens or if I should attempt to remove the camshaft and check head gasket and pistons but to do this I need to lock of the engine for the timing? Can any one help or advise me? Could this break down be the end of the van? Possible leaky injector damaged pistons or the rings and the loose arms not opening the outlet correctly? Sounds like it wasn’t to go. Thanks everyone
