I seem to have a fuel issue, just bought this van with problems cheap, ordered can bus switched cable for forscan, read the codes, sorted all those things, fitted new turbo, feed and return pipes all genuine, took off the egr and cleaned it so its like new, fresh oil, filter, fuel filter and come to start it, it fired for about 3 or 4 seconds then cut out.
I notice that the fuel supply pipe from filter where it sort of has that quick release bayonet fitting on top of pump is somewhat loose and I think its leaking there.... Is it likely to be the spigot that's knackered on the pump, or is the supply line prone to fouling an oring inside or something? My front battery is dead now from messing with other bits on the van whilst working on it so I've got that trickle charging now as I'm sure it needs that to power all the important electronics.
My rear battery was showing 12.9v so cranking ok but don't had 8.4v
Cheers guys
