I have a Transit Mk6 manufactured in 2012, registered in 2013. !40 hp Puma diesel, FWD.
It has a persistent, yet intermittent oil leak. Oil covers the fron side of the engine from the air intake manifold down, on top of the alternator, oil pump.... The leak seems to happen during a longer drive, the stops. I have washed the engine and after that it may stay clean for weeks. I have had the intake manifold seal changed to new, but the leak re-emerged. The engine has been partly rebuilt, the bottom half has about 65000km on it, the rest is older, some of it dating back to original engine and 396000 kms. There is some breathing from the oil cap and dipstick when removed and on idle. I checked the breathing tube going into the air intake tube and some breathing was happening fromfrom there too.
Engine oil gets all black and dirty looking fast, after a few thousand kms.
I am suspecting injector seals, blocked EGR/breathing system, or jammed piston rings. What is wondering is that the leak happens randomly but then it leaks quite bit.
Any ideas or experiences about such a problem?
