Lowering Fuel Tank
Lowering Fuel Tank
Postby nottery » Mon Jul 22, 2019 3:22 pm
Was wondering how difficult it is to lower the tank to diagnose & repair a leak, not sure whether its from a cracked filler/breather hose, or a screw from the ply lined floor (my bad). Only happens when the tank is full. Tank is less that 1/4 full ATM. Can you just lower it a little? My only concern is, when disconnecting all the hoses is it possible to get air in the fuel lines?
If it is a hole in the top of the tank from a screw... I have read people saying you can repair with a screw coated in sealant, a rivet, Hot glue gun, or Epoxy resin,
Think i am leaning towards Epoxy resin.
Whats your recommended method?
Thanks.
2006 Ford Transit Diesel, Mk6, 125 T350, DuraTorq-Di, D0FA
LWB, High top, Ex-Postie Van.
nottery
Re: Lowering Fuel Tank
Postby dumper » Mon Jul 22, 2019 9:18 pm
As for lowering the tank if you get it low on fuel support it on a trolley jack with a pice of wood on top to spread the weight undo the tank straps and slowly lower the tank release the pipes from the clips on body it will come down low enough to get a good look at the top of it
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby aidank1981 » Tue Jul 23, 2019 10:27 am
i have this issue too (SWB mk7 FWD 85ps) didnt think of the screw issue but i didnt fit my flooring, i assumed it was one of the upper access hatches leaking, doesn't seem to be the filler or breather on mine either but will watch this with interest!
see this thread too
viewtopic.php?f=5&t=70686
aidank1981
Postby nottery » Tue Jul 23, 2019 10:49 am
Had a quick look under the van today to see what the job entailed and noticed the breather tube was cracked near the union on the tank. The whole breather tube looked in bad shape. Could definitely see fuel running down the side of tank coming from the top after filling up. Possibly from the cracked breather, but won't know until i drop the tank a bit. Have about 1/8 of a tank ATM, Hopefully get some dry weather tomorrow. Will let you know how it goes.
nottery
Postby johnpietila » Sat May 15, 2021 8:57 pm
HI from John 'down under'in Aussieland
How did you go lowering the tank? Mine leaks if filled right up (for a long trip etc) Would like to know how much I can lower it without straining the inlet/outlet fuel lines and level sensor cabling etc.
John Pietila
johnpietila19@gmail.com
2010 6 m van set up as an ex rental motorhome, well done
johnpietila
Postby dumper » Sun May 16, 2021 7:17 am
When I lowered my mk 6 I only dropped it about 6 inches and that was on a ramp it was very low on fuel and I removed the filler pipe at side of the van . If you want to lower it even more you should be able to unclip the pipes on the body enough to lower it a bit more and unclip the pipes on the sender unit .the mk8 was more difficult as I had to twist the tank to lower it.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby scas » Sun May 16, 2021 11:22 am
undo the 2 jubilee clips for the 2 hoses, jack under the middle, undo the 4 bolts, itll lower to the ground without having to undo the fuel lines, the leak when full is usually from a cracked breather hose
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Postby johnpietila » Mon May 17, 2021 12:40 pm
Thanks, this sounds a logical source of leak
John Pietila
johnpietila
Postby johnpietila » Mon Aug 23, 2021 9:37 pm
Yes mine was a cracked vent pipe as well
Thanks to all
John Pietila
johnpietila
