2011 Mk7 Gearbox Oil Change
Postby Pro-Active » Sun Aug 11, 2019 10:01 pm
Hi could someone let me know how to change the gearbox oil on my 2011 fwd mk7 transit and what grade and type of oil to use.
Many Thanks For The Advice
Pro-Active
Re: 2011 Mk7 Gearbox Oil Change
Postby Pro-Active » Sun Aug 18, 2019 2:51 pm
Hi could anyone give me any information would be grateful.
Cheers
Pro-Active
Postby knobby1 » Sun Aug 18, 2019 11:41 pm
Pro-Active wrote:Hi could anyone give me any information would be grateful.
Cheers
5 or 6 speed..??
Oil is Ford spec: WSD-M2C200-C (75w90 gear oil) and capacity is approx 2.1 Liters. Filling up to the bottom of the fill hole is sufficient as you'll normally never get all of it out.
Postby Pro-Active » Tue Aug 20, 2019 9:10 pm
Thanks for the information it's a 6 speed will it be 2.1 litres to fill to the correct level.
Cheers
Pro-Active
Postby knobby1 » Wed Aug 21, 2019 12:57 am
Pro-Active wrote:Thanks for the information it's a 6 speed will it be 2.1 litres to fill to the correct level. Cheers
2.1 Liters is the total gearbox capacity.... for when the gearbox is totally empty, after being rebuilt/re-assembled for example.....but as mentioned, you'll never get it all out when just doing a normal oil change, oil gets caught in all the nooks and crannys in the housing etc..etc.... You'll possibly get ~1.7-1.8Liters back in after a normal drain, just fill it until it dribbles out of the fill hole, ( and all over your head), and you'll be good to go.
Postby Pro-Active » Thu Aug 22, 2019 7:00 pm
Thanks Lord Knobrot much appreciated
Pro-Active
