by davyjcb » Mon Aug 19, 2019 10:25 am
If your close to someone with ids the full oem system is better you will not be able to put the oem wheel on or attach the aftermarket control to the wheel either ,there's not enough connections in the clockspring Ford use a resistance ladder to tell the cruise what you want it to do 2 wires and as far as I know the aftermarket units tie into the throttle pedal circuit .Also clutch and brake need tied in, the latter 2 won't matter to the wheel.
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
