Egr fault, p0404
Egr fault, p0404
Postby mjsroofing » Wed Sep 11, 2019 9:09 am
I'm guessing this means it's stuck open.
How hard are they to remove and clean,
09 plate 2.2 fwd.
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Re: Egr fault, p0404
Postby loot » Wed Sep 11, 2019 9:12 am
I think that is range performance and usually means the head is worn out.
You can get new ones off tpuk
I'd get the updated black 1.
https://rover.ebay.com/rover/0/0/0?mpre ... 3124486264
50 quid :P
Is it fixed yet? 8)
Ids map here
loot
Postby mjsroofing » Wed Sep 11, 2019 9:16 am
loot wrote:I think that is range performance and usually means the head is worn out.
Cheers m8, while your here, I'm thinking of changing the scv while I'm working on van, it hasn't failed yet but I think it's starting to and want to catch it early.
Where would you recommend getting one from, I remember stories of some new ones not working.
50 quid :P
Is it fixed yet? 8)
mjsroofing
Postby loot » Wed Sep 11, 2019 10:01 am
I have to say Ford unfortunately :(
You could try pf jones.
Have you checked the prv? Have you done the learns? If it the prv is OK and passes the learns and runs smooth then I don't see a reason to do them but have you don't the injector leak off test first because more often than not it will fail the pilot and you'll be stuck with engine malfunction which is a right anus and you'll wish you never started it lol.
Ids map here
loot
Postby knobby1 » Wed Sep 11, 2019 10:39 am
loot wrote:I have to say Ford unfortunately :(
I've played with a couple of SCV's...they're just a simple variable voltage solenoid, most times the sliding piston gets wear/score marks on them and they tend to stick a bit...which causes them to undershoot & overshoot, hence the hunting idle. I changed mine for a new one a few years ago...but as an experiment, ~six months later I had a "thought" and polished the piston and it's bore on my original one, fitted it back in.... and it's still in there today running a sweet as a nut.
Postby loot » Wed Sep 11, 2019 3:14 pm
To much polishing and you could go blind :shock: :lol:
Ids map here
loot
Postby mjsroofing » Wed Sep 11, 2019 6:46 pm
The van hasn't failed yet, I do a learn every service and it aways passes, ive just notice an increase in the hunting, nothing major yet but I thought if I catch it early it won't blow the prv.
mjsroofing
Postby knobby1 » Wed Sep 11, 2019 8:47 pm
loot wrote:To much polishing and you could go blind :shock: :lol:
Have you not seen my white cane..?? :wink: :lol:
Postby mjsroofing » Fri Sep 13, 2019 2:55 pm
Just p1103 come up too,
I'll clean egr , inlet etc on Sunday and see how things go.
mjsroofing
croncroncron
