by Beth_a_ny » Mon Oct 21, 2019 12:52 pm
Hello all, I am new here but I have an issue and need some help
We have had to do an engine replacemnt in my MK7 2.4 RWD. We bought another van with a recently reconditioned engine in and moved this into my van. This went well, when we moved the engine we also bought the PCM, fuse box and all the wiring thinking this would be easiest. When we turned the key we just got a red flashing PATS light and - - - - on the dash. We then called an electrician to code the keys and check everything. This kept failing, his computer could find all the individual units in the van but the PCM would not talk to the body control unit. He tried everything, we tried both PCM's. All he could suggest was that we changed the whole wiring loom and call him back.
So we did this and van then started straight away, even though we thought it wouldn't as keys were never coded. Electrician came back on saturday as my engine management light is on and i still want the injectors checked. Unfortunatlly this was still unsucssesful as his computer just kept saying PCM failed, but we know it is working as van is running!
So now i'm stuck, i dont want to use the van as i don't want to damage anything, the engine is not sounding smooth and even like it did in the old van. The electrician suggested i ask on here or the forums to see if anybody else has had a similar problem of not being able to communicate between PCM (we tried both again) and computer? I am REALLY REALLY hoping there is an easy fix for this somewhere. Electrician had both ford IDS and other software
