by Evom » Wed Nov 06, 2019 8:31 am
Update for anyone with similar problems.
Replacing the idle speed control valve didn’t fix my issues and engine started running even worse. Symptoms were revs sticking (high) when changing down through the gears, uneven idle speed, sometimes high or too low, won’t idle and stalls. All these were intermittent and highway speeds were relatively ok. Stop start traffic was the worse!
Anyway, changed out the TPS Sensor (throttle position sensor) mounted on the Throttle Body and cleaned up the body and butterfly with throttle body cleaner. All good after that and engine running normal again and symptoms all gone, including the check engine light. The code came up with idle speed out of range so points to the TPS anyway. Old TPS didn’t rattle and seemed fine but I assume electronics inside were stuffed.
Made sure to disconnect the battery and also ran a wire across the (disconnected) negative lead to the positive on the battery terminal to discharge any remain capacitors and to reset modules.
Started first go and let it idle from cold for about 15 mins then drive.
Hope this helps other with a 2.3 petrol transit. Not many of us it seems!
Cheers
