by MattD » Wed Oct 23, 2019 5:43 am
I understand. The transit doesn't necessarily need an amplified aerial, but if you've had a new one fitted, including new cabling from aerial to radio, and hasn't improved, then there's nothing to lose. Should be easy to fit too as your new radio will more than likely have a +12v output wire which can be used to power the amplifier when the radio is on.
