loot wrote:Is that a generic fuel filter? Mann or ford should be used for tdci fitment.
Are there any warning lights on?
Both batteries will need checking too, I've known a bad main battery to cause hunting when failing.
Check the air filter is clean and dry.
If no different after that then it could be a few things, well need checking by a mechanic who knows the van
Good spot on the fuel filter - we just fitted it and its not OEM - the old one was a ford one - I bought this service kit on ebay and assumed it was all good:
https://www.ebay.co.uk/itm/FORD-TRANSIT ... 2749.l2649The old Ford Fuel Filter was no different though.
There are no warning lights, he's recently had some battery issues but they are now 100% charged - both on 12.6V, so that shouldn't be the issue. Would you recommend taking them to a car shop to get tested properly?
Brand new air filter installed as well, same noise before & after.
