the saga continues
the saga continues
Postby monkey69 » Mon Oct 21, 2019 11:23 am
Even though i got the van started after replacing prv & scv van gets to temp ok . tried to do pump learn and injector learn and now it wont do it as i have code p0180:15-28 code and keeps coming back even after clearing code and re running program......god this van is doing my head in :x
any advice please
2009 2.2 mk7
monkey69
Re: the saga continues
Postby knobby1 » Mon Oct 21, 2019 11:41 am
P0180 is a fuel temp issue.... during the learns the fuel temp must stay within a small range, if it strays outside this range, the learns will fail.
I like to start the learns from a cold engine and commence the process as soon as the temp is just in the lower limit, the temp will rise during the learns and it needs to be kept under control. I dribble the garden hose over the fuel rail whilst doing the learns and this seems to work fine.
Postby monkey69 » Mon Oct 21, 2019 11:44 am
thanks for that, you start with pump or injector learn first?
2009 2.2 mk7
monkey69
Postby knobby1 » Mon Oct 21, 2019 12:25 pm
monkey69 wrote:thanks for that, you start with pump or injector learn first?
Pump, pilot, injector. But be sure to reset the PRV counters first.
Also be aware the process will fail if the injectors are not well. The pumps very rarely fail.
How many k's on the beast..?
Lord Knobrot.
Postby monkey69 » Mon Oct 21, 2019 1:47 pm
Cheers lord knobb, i have completed the test pump and injectors and all went fine,and no codes found, i tried resetting the prv etc but kept coming up with this function is not supported..this was back in september and i sent forscan email and this is what they said.
hello forscan,
when i try to reset the fuel pressure relief valve and the and the open count learned values it comes up with service procedure not supported,
I though i may have been able to do this or is it in another version of forscan?
thankyou
Hello,
It is not a bug. The function is available only for certain PCM/firmware versions. Your PCM/firmware doesn't support it (doesn't require this function).
2009 2.2 mk7
monkey69
Postby monkey69 » Mon Oct 21, 2019 7:31 pm
well been for a run and all appears to be ok so far just see what it starts like in the morning :?
2009 2.2 mk7
monkey69
