Shirazman wrote:often requiring 3-4 attempts and a bit of accelerator.Sent from my SM-N975F using Tapatalk
knobby1 wrote:...Many years ago my Father used to pump the throttle a couple of times on his old Cortina to help it start....
knobby1 wrote:Shirazman wrote:often requiring 3-4 attempts and a bit of accelerator.Sent from my SM-N975F using Tapatalk
This does nothing, the throttle is "Fly-by-wire" and the PCM disables the pedal until a stable idle of ~800rpm is achieved.
Many years ago my Father used to pump the throttle a couple of times on his old Cortina to help it start....he still does it today in his newer fuel injected cars...I've told him it does nothing but he still believes it does..
Hi John,johnenigma wrote:Your sliding door not central locking not working properly is probably a rubber tyre coming off the centre roller allowing the door to drop down, missing the contacts on the post.
Sent from my SM-G955F using Tapatalk
Cider Andy wrote:knobby1 wrote:...Many years ago my Father used to pump the throttle a couple of times on his old Cortina to help it start....
If it had a Weber 32/36DGAV you were supposed to, to set the choke. But yes, it does nothing whatsoever with a fly-by-wire throttle....
