Airthies wrote:First before doing anything else...
Do injector leak off test, (4mins at idle - 20ml to 40ml)
Then injectors out and get them tested if you want.
Cut and replace injector washers,
Check clamps are the upgraded ones and replace if required,
Replace injector bolts (there stretch bolts and should only be used once)
Replace leak off pipe seals to be on the safe side.
Make sure injectors go back in the same hole they came out of and code in any new injectors.
SCV & PRV if you want to.
Do pump and pilot learns and reset counters.
Jobs a goodun
Clamps and bolts from Ford
Injectors, copper washers, seals, SCV & PRV from PFJones.
dymondaudio wrote:
Thank you for the info, how much should I expect to pay for the clamps and bolts from Ford?
No it shows its blocked or restricted operation.dymondaudio wrote:My cylinder balances are reading as follows (cold)
1: 2. Something
2: 2. Something
3: -6. Something
4: 2. Something
Does this indicate that injector 3 is screwed?
Airthies wrote:No it shows its blocked or restricted operation.dymondaudio wrote:My cylinder balances are reading as follows (cold)
1: 2. Something
2: 2. Something
3: -6. Something
4: 2. Something
You need to take off leak off pipes, and connect hoses to each injector and measure what comes out after 4mins.
Run it till all 4have some in the bottle and hoses are full. Empty bottle and then restart and time the test.
Mane sure you plug the leak off pipe ends as that'll let in air and the van will stop
dymondaudio wrote:Can injector seals cause this massive imbalance in cylinder 3? It's running like a bag of nails at the moment. What causes an injector to become blocked / restricted other than failure of the injector itself?
knobby1 wrote:dymondaudio wrote:Can injector seals cause this massive imbalance in cylinder 3? It's running like a bag of nails at the moment. What causes an injector to become blocked / restricted other than failure of the injector itself?
No, the seals are unrelated to injector performance, they basically just act as a compression seal between the injector and the cyl head. The "other" upper seals just seal the oil and crankcase fumes from getting out between the rocker cover and injector.
Injectors themselves can block internally and fail electrically. We must remember that these injectors are running at upwards of 30,000psi during normal operation, I'm surprised they last as long as they actually do.
dymondaudio wrote:looking around for a new injector, on the top of the injectors there is a number beginning with F which I believe is the correction factor?
The only other number I can see is 06K03660 Does this mean that the part number is on the side of the injector and needs to be out in order to check it? I was hoping to purchase one of thesehttps://www.ebay.co.uk/itm/FORD-TRANSIT ... 2164428212
But want to make sure it's the correct one especially as mine is the 140 The compatibility checker on the listing says it fits the 140
