andz327 wrote:Diesel doesn't go near the turbo,
Slack injectors will blow fuel past their compression seal(copper washer) straight into the cam box
Could be faulty injector over fueling
Possibly hole in a piston
ANDZ
andz327 wrote:Thought the light came on at 18k if its 20k then it's every 20k she gets serviced
ANDZ
Nope when servicecomes on dash, if i done every 5k like someI'd be doing an oil change every 7 days when I'm busy, quality oil keeps her happyJay2018 wrote:andz327 wrote:Thought the light came on at 18k if its 20k then it's every 20k she gets serviced
ANDZ
Probably is every 18k, I meant 20k ish in general. I just thought you had shorter intervals because it made it to such a high mileage.
andz327 wrote:Is there Loads of oil around base of injectors??
ANDZ
andz327 wrote:Maybe thats where the fault is , injectors not seat properly and the blow by has dieseled yer oil making it mega thin and pissin through your turbo and like Bambi said if its put oil level way up then it'll be blowing into the breather also, i take it you used new bolts and the newer clamps and recut the seat
ANDZ
Patvan247 wrote:andz327 wrote:Maybe thats where the fault is , injectors not seat properly and the blow by has dieseled yer oil making it mega thin and pissin through your turbo and like Bambi said if its put oil level way up then it'll be blowing into the breather also, i take it you used new bolts and the newer clamps and recut the seat
ANDZ
Do you think? Yes new clamps, bolts, copper sealing washers and seats recut. Would it not pass up through the rocker cover around the injectors if it was that?
knobby1 wrote:Patvan247 wrote:andz327 wrote:Maybe thats where the fault is , injectors not seat properly and the blow by has dieseled yer oil making it mega thin and pissin through your turbo and like Bambi said if its put oil level way up then it'll be blowing into the breather also, i take it you used new bolts and the newer clamps and recut the seat
ANDZ
There's room between the copper seals and rocker cover seals, if the copper seals are not perfect and clamps are not holding well, fuel can get between the seals and eventually end up in the sump, hence all the fuel in your oil.
Patvan247 wrote: Seems possible! Would this be enough to over fill the sump and cause runaway?
Patvan247 wrote:ned wrote:Patvan247 wrote:Checked breather and return pipe today and both clear. I’m thinking compression test next. Any other ideas? There defiantly something causing oil to get into the inlet. My intercooler and pipe work was full of oil also pipe work from and to the EGR.
This definitely sounds like the turbo has a problem, with the amount of oil in the pipes, intercooler ect there not many places the oil can come from.
We had a Renault migraine that the turbo went on, it didn't run away just smoked like a bitch and kept overheating, new turbo and all way fine, for 2 weeks then it popped a piston
I dropped the oil today and there is masses amount of diesel in there! would this indicate anything or would this still happen if the turbo was at fault?
