Dav06gab wrote:Thanks for your reply. Oh will never bleed them again. I’ve noticed today drain sensor pipe is missing, could this caused such an issue ?
Fuel hoses are like new and couldn’t see anything obvious.
Dav06gab wrote:Thanks for sharing the info. I will strip the filter assembly and have a close look at the injector hoses tomorrow. My other 12 plate 2.2 mk7 has a different filter housing which I never had problems with after changing the filter, just wondering if it’s a straight swap onto my11 2.4 ?
knobby1 wrote:Dav06gab wrote:Thanks for sharing the info. I will strip the filter assembly and have a close look at the injector hoses tomorrow. My other 12 plate 2.2 mk7 has a different filter housing which I never had problems with after changing the filter, just wondering if it’s a straight swap onto my11 2.4 ?
Your 12 plate will be a Euro-5....the 2.4 will be Euro-4, different filter setup for each. Also different fuel injection system, Euro-4 will be Denso, Euro-5 will be Siemens.
Dav06gab wrote:Forgot to add after scanning there is no DTC fault at all.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
