v8dave wrote:FWD or RWD?
Mk6 or mk7?
v8dave wrote:Could be you've got a poorly waterpump, the drive splines on the fwd waterpump wear and fail.
Or maybe the air flap that controls the airflow through the heater matrix is not moving properly and letting too much cold air around the matrix instead of through it.
bambi mk 1 wrote:Did you use a genuine t/stat There is a t/stat in the oil filter /cooler too
