Jim Archer wrote:Leave a bigger air gap between throttle pedal and carpet
Jim
AnarcoDave wrote:Im currently getting about 20mpg from my 06 plate 2.4 diesel LWB ....
winterheating wrote:Check it’s running at the correct temp to start with, so so so common to run cold.
I have had a lot of work done recently on it and it has had a good service ....
AnarcoDave wrote:winterheating wrote:Check it’s running at the correct temp to start with, so so so common to run cold.
How would I check .. just keep an eye on the temp gauge?
how would I resolve it if it is a problem?
ned wrote:AnarcoDave wrote:Im currently getting about 20mpg from my 06 plate 2.4 diesel LWB ..
What sort of work?
Have you visually inspected all boost pipes for hole/splits, inlet manifold for cracks, turbo actuator is moving ect
haadee wrote:ned wrote:AnarcoDave wrote:Im currently getting about 20mpg from my 06 plate 2.4 diesel LWB ..
What sort of work?
Just stepping in this topic for a quick question as turbo actuator is being talked about now.
I tried to move the rod of the actuator (on my own transit, 2.4 125ps tddi) by hand when engine was shut down.
It was not really possible to do this, I'm guessing thats not what it should be like.
What is usually the problem with these?
STEVE P wrote:Tie wrap a 25mm piece of wood to the underside of the throttle pedal, you will be amazed at the difference it makes and hardly makes any difference to the performance.
Steve
