Caliper sliding pins
Postby littlespoon » Sat Jan 04, 2020 3:50 pm
Hi just a quick question. I’ve changed my front pads on my vans for years. Easy enough. This time I was cleaning out the caliper and saw the top slider bolt rubber was split. It’s all rusty inside and there’s no movement on the pin at all. I usually only loosen it to change the pads so I guess I’d never taken it out.
So basically it’s stuck like a mofo and can’t get it out. Any ideas on removal?
Transit 2012 t260 fwd swb
littlespoon
Re: Caliper sliding pins
Postby Airthies » Sat Jan 04, 2020 4:58 pm
Lots of loosall/WD-40 (other brands are available ) chap it in and turn it, then if possible put a socket or bit of pipe and plate over the top and with a bolt use that to pull it back out, might have to do it a few times. To free it off.
Sent from my A55ho11 using Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby littlespoon » Sat Jan 04, 2020 5:31 pm
Thanks for the reply, taken the advice, I’ve sprayed a load of gt80 all over it, will attempt to pull it out tomorrow. Guess I can’t be too heavy handed ?
littlespoon
Postby andz327 » Wed Jan 08, 2020 12:53 am
Like the Legend says plenty loose juice and some persuasion and it should start to move, then clean it a bit and some coppersh!t and your sorted , you can buy the slide kit seperately but the actual mounting bracket complete with slides doesn't cost that much more to be honest
ANDZ
andz327
Postby Jim Archer » Wed Jan 08, 2020 10:40 am
CV joint grease on slider pins. You'll thank me in 20K miles time when the Copperslip will have set like concrete.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Jay2018 » Thu Jan 09, 2020 4:52 pm
I think you might be able to try it the other way round. Instead of clamping down the caliper and trying at the pin; try putting the pin end in the vice and hitting the caliper to turn and loosen the pin.
2012 MK7 Transit Trend 125 T350 6 SPD FWD MWB MR (Frozen White) :D
2010 MK7 Transit Jumbo 100 - SOLD :(
Galant VR4 8th Gen Type S(TT), 300ZX(TT) + S14A(T), Supra MK3(T), Golf MK4 1.8(T), GS300 & Civic EG9 VTI (ALL SOLD)
Jay2018
Postby littlespoon » Mon Jan 20, 2020 7:46 pm
Thanks for the advice !
It was rusted in so bad I got a second hand caliper carrier for £30 and replaced it.
littlespoon
Postby andz327 » Wed Jan 22, 2020 3:13 pm
littlespoon wrote:Thanks for the advice !
What £30 for one of theseImage
ANDZ
andz327
Postby Jay2018 » Thu Jan 23, 2020 4:17 pm
ANDZ
I was wondering and then realised he paid £30 for a SECOND HAND one. Hopefully he took the pins out cleaned and regreased them before fitting...
Jay2018
