Gearbox
Gearbox
Postby oldyellar » Thu Jan 09, 2020 8:51 pm
I have eu5 mk7 tipper and the prop shaft has snapped off from the gearbox :cry: it appears to be the part that slides into the gear box that has snapped! The part of the gear box you bolt the prop to on the prop.
My question is can this part be changed? The part the prop bolts to that comes out the rear of the gear box.
Thanks john
oldyellar
Re: Gearbox
Postby knobby1 » Thu Jan 09, 2020 10:55 pm
This bit..?
http://www.catcar.info/ford/?lang=en&l= ... UwMDcrMTMz
I gotta ask...How?
Re: Gearbox
Postby oldyellar » Fri Jan 10, 2020 12:26 pm
Not sure if that I the part I'll need to further inspect it today.
I suspect the driver was trying to do a bit of drifting :x
oldyellar
Re: Gearbox
Postby Airthies » Sat Jan 11, 2020 1:45 am
If it's snapped the drive flange that comes out the gearbox I'd be concerned that it's not bent the output shaft too, and that there's no other damage down the driveline or chassis as I reckon that'd take some effort to damage that.
Have a look, get some pics an let's see where we go,
The flange should be replaceable easy enough, though if the rest is ok.....
Sent from my A55ho11 using Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Gearbox
Postby dumper » Sat Jan 11, 2020 9:28 am
Is the flange held on by centre Bolt and come lose and snapped the head off the bolt had a Hgv do it once was lucky the snapped off bits were finger tight and came out easy new bolts fitted and back on with his delivery
Re: Gearbox
Postby oldyellar » Sun Jan 12, 2020 5:06 pm
Thanks for the replies guys this is second time this had happened. First time due to driver error the prop came up and hit the tipper frame and done a bit of damage
The driver went from 5th to 2nd gear and thsts how it happened first, he had it repaired as I was on holiday never managed to look at it.
This time I suspect it was wheel spinning/ drifting as the passenger told me there was a bit of drifting before it broke :evil:
Truck only done 27k before the display went off due to tachometer removal it must roughly have 50k on it now
oldyellar
Re: Gearbox
Postby oldyellar » Sun Jan 12, 2020 5:08 pm
Few pics
oldyellar
Re: Gearbox
Postby oldyellar » Fri Jan 17, 2020 7:52 pm
Any ideas guys? I'm going to get a look at this at the weekend if I get a minute.
Are eu4 nd eu5 gearboxes the same ? Mt82?
oldyellar
Re: Gearbox
Postby Jay2018 » Mon Jan 20, 2020 11:06 pm
Have you got a picture of the actual flange end of the gearbox?
2012 MK7 Transit Trend 125 T350 6 SPD FWD MWB MR (Frozen White) :D
2010 MK7 Transit Jumbo 100 - SOLD :(
Galant VR4 8th Gen Type S(TT), 300ZX(TT) + S14A(T), Supra MK3(T), Golf MK4 1.8(T), GS300 & Civic EG9 VTI (ALL SOLD)
Jay2018
Re: Gearbox
Postby oldyellar » Wed Jan 22, 2020 7:51 pm
Jay2018 wrote:Have you got a picture of the actual flange end of the gearbox?
I dont it's the 3 bolt one though.
We've got to the bottom of this now the, bolts came loose that hold the propshaft to the flange on the gearbox, causing it to rip that screw in end out the tail of the gearbox.
Had the full prop renewed and got that part that was ripped out for £150. Vehicle off the road for over a week though :evil:
oldyellar
