I have eu5 mk7 tipper and the prop shaft has snapped off from the gearbox it appears to be the part that slides into the gear box that has snapped! The part of the gear box you bolt the prop to on the prop.
My question is can this part be changed? The part the prop bolts to that comes out the rear of the gear box.
Thanks john
