Hi all
Looking for recommendations for a obd set up that will do pump learn etc.
I have a launch dongle that I use for clearing codes but wondering whats about with more options
61 plate 2.2 trend 280mwb
Tia
Steve
ihaddigan wrote:are these ELM327 USB just online order..
ian
spg handyman wrote:Thanks all, got one and had run through everything. Been having problems with sluggish pull away then clears and goes OK.
Got new egr valve and have run all the learns.
No4 injector not setting up on pilot Learn.
I have found that she is breathing heavily and sounds like I might have an injector seal leaking.
Wondering if that would cause the injector not to set up or is that at fault as well,
I'm new to transit mk7s so over to you experts
Users browsing this forum: Burf86
