loot wrote:When I plug my ids in and go to module update online it'll check if there's a later software available
I'm sure someone once showed a way to find out on motorcraftservice but I can't remember
loot wrote:On v86 with licence it will go online.
loot wrote:Just have it online and go to module programming then module reprogramming then pcm and it'll check it'll say there is an update or no update.
If it asks to update the vcm or anything like that then no.
mjsroofing wrote:loot wrote:Just have it online and go to module programming then module reprogramming then pcm and it'll check it'll say there is an update or no update.
Cheers m8, I'll check it soon, thinking of getting it mapped and want to make sure everything is up to date and working mint first.
loot wrote:mjsroofing wrote:loot wrote:Just have it online and go to module programming then module reprogramming then pcm and it'll check it'll say there is an update or no update.
That's a good plan, but you need to only do that if they are going to read your map then modify it then write it back, if they have a generic map then it won't matter. And I'm guessing a good mapper will check and update as needed
Can you do successful pump and pilot learns? Again they will likely need doing afterwards. But it doesn't harm it to be done before.
mjsroofing wrote:loot wrote:[qote="mjsroofing"]loot wrote:Just have it online and go to module programming then module reprogramming then pcm and it'll check it'll say there is an update or no update.
