Hey guys,
only me I have a pretty simple question,
Can I buy a leisure battery and put it in where the second battery should go? will it have a vent hole or would I need to make one?
I will use an aftermarket split charger so I don't have to have anything updated. So a fused live from my main battery to the new battery then ground the split sensor and the negative battery terminal to the chassis.
My thinking of putting it where the second battery should go is to keep the job tidy and then there isn't any wires running anywhere.
Has anyone does this here before?
Thank you in advance - I did use the search function but not specific to my question i have seen peoples camper conversions putting a battery in the rear or adding a second battery to a single battery mk7 and updating the software for it to charge 2 batteries.
