mossman_uk wrote:Hi
Tried the sliding door contacts too
The loom at the back appears to be in perfect nick
mossman_uk wrote:Would the sliding door contacts reopen the front doors only?
mossman_uk wrote:Also in addition, when I switch the lights on the warning buzzer is constantly on, like a door is open.
Thanks!!
Airthies wrote:The key factor here is this little bit of infomossman_uk wrote:Also in addition, when I switch the lights on the warning buzzer is constantly on, like a door is open.
Thanks!!
If the warning buzzer is on constantly then it must be the driver's door as that's the only one that activates the buzzer
Check the plug at the door pillar they have a habit of corroding, or the lock unit the switch is faulty.
Thanks!!
Not on my mk7s it's all in the lock.bambi mk 1 wrote:Airthies wrote:The key factor here is this little bit of infomossman_uk wrote:Also in addition, when I switch the lights on the warning buzzer is constantly on, like a door is open.
Thanks!!
The buzzer isnt worked of the lock unit,there is a switch on the a post for that
Not on my mk7s it's all in the lock.Airthies wrote:bambi mk 1 wrote:Airthies wrote:The key factor here is this little bit of info
[quote="mossman_uk"]
Thanks!!
bambi mk 1 wrote:I was gonna say the op has a mk 6 in his signature but I better not
Users browsing this forum: Majestic-12 [Bot], thrud
