Edturns wrote:Hi guys and thank you for accepting my request to join.
Edturns wrote:I have a 2004 2.4 diesel engine which I am told is referred to as the banana engine. (no idea why)
Edturns wrote:Any advise would be kindly appreciated
Altransit wrote:Aha You said it was a Mk6
LDV Convoy was fitted with either a 75ps or 90ps 2.4 TDDi Duratorq and there was no info on the doors!
The 90ps was the same engine but intercooled, and had a cutout above the front bumper for the intercooler air flow
bambi mk 1 wrote:Run the engine with the oil cap off and see if it is puffing smoke out the filler hole
Edturns wrote:bambi mk 1 wrote:Run the engine with the oil cap off and see if it is puffing smoke out the filler hole
will do tomorrow as I have had enough of this van for today, but what would it confirm if it does smoke from the oil filler cap?
Edturns wrote:Morning Guys,
Well, still no success, I have changed the filter housing and filter, after filling the filter with diesel and spending what seemed like forever bleeding the fuel to the injectors and same story it eventually ran on tickover, but what I did notice is the fuel filter isn't filling up, after the engine cut out I took the filter off again and it was more or less empty. the drain screw is fully tightened. any advise please?
