by greendragon3 » Tue Jan 21, 2020 5:14 pm
hello again , im officially bald because i have pulled most of my remaining hair out trying to sort this problem , i've fitted the heated mirrors connected up all the correct " plug and play " harnesses got a correct heated mirror switch off ebay but no go , now today out of utter frustration i switched round a few of the relays under the glove box and low and behold the switch lit up and the mirrors started thawing out , only problem is they are on all the time even when i knock the van off !! i switched the relay back and went for a cup of tea cos i am on the verge of cracking up here , any help on the correct relay and where it goes would be most helpful , also how do i check the existing one to see if its not faulty ??
keeping the blue oval alive in the north west .
2004 90T350 DOUBLE CAB TIPPER .
