Scotty7940 wrote:Hi can any one help I got a mk6 125 hp transit, it will only start when I spray easy start, once it’s running I can drive it all day soon as I switch it off it won’t restart. I was told to Change the filter housing as there is a pump on top of the housing I have done that and it’s still the same any help is appreciated many thanks scott
knobby1 wrote:Scotty7940 wrote:Hi can any one help I got a mk6 125 hp transit, it will only start when I spray easy start, once it’s running I can drive it all day soon as I switch it off it won’t restart. I was told to Change the filter housing as there is a pump on top of the housing I have done that and it’s still the same any help is appreciated many thanks scott
Is it TDDi or the FWD TDCi...??
Have you had the codes read..??
ned wrote:knobby1 wrote:Scotty7940 wrote:Hi can any one help I got a mk6 125 hp transit, it will only start when I spray easy start, once it’s running I can drive it all day soon as I switch it off it won’t restart. I was told to Change the filter housing as there is a pump on top of the housing I have done that and it’s still the same any help is appreciated many thanks scott
Lift pump on the filter suggests it's an early 2.4 tddi
Scotty7940 wrote:So I have diesel at the injectors have had it read no codes, spray and it starts turn it off won’t start I’ve took the fuel pipes off checked them I’ve Chang the filter housing and filter still same any other ideas other than getting injectors checked? Which I will do wen there open
