Hi,
new Transit is having a sound somewhere from the engine. It follows the revs. A friend of mine says its the flywheel.
in this youtube video a viewer is saying that it could be the injector clamps. https://www.youtube.com/watch?v=JE5Y8CF74PM
mind you that mine is not as excessive as his, but its kind of the same sound and my transit is leaking oil from all four injectors (i pressume, i can only see the two on each side)
i wanted to get this done for a while now anyway. i found complete kits from the UK on ebay. i read somewhere that the bolts need replacing too. is that correct?
https://www.ebay.com/itm/202130364644
https://www.ebay.com/itm/253369360552
which of the two sellers do you prefer.
to sum up:
could the noise come from the injector clamps being lose.
will i need bolts aswell
bonus info: i have been driving with low revs for quite a while to avoid that sound and now the dpf is full. good times.
