Airthies wrote:Yes the port gets smaller as it comes up from the engine an it's probably had a bit squeezed into the port the dragged up and blocked it up.
Take it all off, make sure port through water pump is clear then refit your old pump, you'll need a new brake boost pipe as the end of it will be melted.
dymondaudio wrote:If I run it without the vac hose connected will that do any damage?
I won't be driving it anywhere it just may be a while before I can get a vac hose delivered.
knobby1 wrote:dymondaudio wrote:If I run it without the vac hose connected will that do any damage?
You'll not have any brakes or heater controls, but shouldn't be an issue.
