frankiepeter wrote:yes had new filter bosch i think.where do i get the codes from.
Bosch filters are fine I've done over 300,000miles in years with Bosch, you have a laptop you can download FORSCAN free and buy an switched elm327 unit (see tunnel rat electonics)which connects your van to your laptop and you'll be able to do your own diagnosticsC & S direct wrote:frankiepeter wrote:yes had new filter bosch i think.where do i get the codes from.
Non genuine ford filters, use the wrong micron filtration, the injectors will wear quicker, diesel systems are very high engineering. Bosch I would like to say know this and produce to same specifications, cheap filters are cheap for a reason etc.
andz327 wrote:Bosch filters are fine I've done over 300,000miles in years with Bosch, you have a laptop you can download FORSCAN free and buy an switched elm327 unit (see tunnel rat electonics)which connects your van to your laptop and you'll be able to do your own diagnosticsC & S direct wrote:frankiepeter wrote:yes had new filter bosch i think.where do i get the codes from.
Sent from my SM-G975F using Tapatalk
frankiepeter wrote:hi ive got a hand scanning tool but it shows no fault codes
C & S direct wrote:Bosch filters are fine I've done over 300,000miles in years with Bosch, you have a laptop you can download FORSCAN free and buy an switched elm327 unit (see tunnel rat electonics)which connects your van to your laptop and you'll be able to do your own diagnosticsandz327 wrote:C & S direct wrote:[quote="frankiepeter"]yes had new filter bosch i think.where do i get the codes from.
frankiepeter wrote:hi. i have now replaced the scv and tried to replace the prv but was unable to slacken the old one off.changing the scv made no difference still just runs for about 15sec.pumping the gas pedal makes no difference to the revs.when i take off the fuel filter it is half empty.not sure if this should be full or not.not too sure what to try next.
