Locking issue
Locking issue
Postby ltk_tmk7 » Sun Mar 29, 2020 12:45 pm
Mk7 transit...
Keyfob wasn't holding much charge, replaced it. New keyfob was equally as bad. Now not taking any charge at all.
No central locking working when manually using key in door either, or using internal locking switches (not sure if it's meant to).
What do you guys suggest?
Lewis
ltk_tmk7
Re: Locking issue
Postby ltk_tmk7 » Sun Mar 29, 2020 1:06 pm
Fuses 74 and 78 okay too...
ltk_tmk7
Re: Locking issue
Postby ltk_tmk7 » Sun Mar 29, 2020 1:21 pm
Jesus front battery 2.7V ….that must be it.
ltk_tmk7
Re: Locking issue
Postby blue estate » Sun Mar 29, 2020 1:49 pm
ltk_tmk7 wrote:Jesus front battery 2.7V ….that must be it.
That’s Fooked , check other battery as well
P/S buy Bosch or other good make don’t buy motor craft batteries
72plt MG 5 ev estate Battery car
blue estate
Re: Locking issue
Postby tibsy » Sun Mar 29, 2020 2:42 pm
Is your multimeter on right setting? Could that actually be 12.7!
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Re: Locking issue
Postby andz327 » Mon Mar 30, 2020 3:06 am
Get a big Bosch for it 5yr warranty Image
Sent from my SM-G975F using Tapatalk
andz327
Re: Locking issue
Postby ltk_tmk7 » Thu Apr 02, 2020 8:56 am
Thanks, gone for the same (Bosch), problem fixed as soon as I replaced it. Other battery in good nick thank goodness.
ltk_tmk7
Re: Locking issue
Postby ltk_tmk7 » Thu Apr 02, 2020 8:57 am
tibsy wrote:Is your multimeter on right setting? Could that actually be 12.7!
Definitely not 12.7! As I checked other battery alongside which was 12.5. New battery in and problem solved, thanks guys.
ltk_tmk7
