andz327 wrote:should be welded in place before arch goes on
Sent from my SM-G975F using Tapatalk
colingo wrote:So like andz327 says you should have this panel , also the curved arch closure panel which extends fwd and upwards which central panels dont appear to show strangely as this is the first to rot out and so starts the chain reaction for the rest.
Re my my soggy sponge in a bay comment have a look in the larger open hole above where i discribed as looking at it today i think it may well be in there both sides. Colin
colingo wrote:Nice work, im currently welding my LWB mid roof mk6. I have started with the front inner wings and arches as these ares failed the mot. Not sure how bad yours are But theyre as rare as hens teeth. I managed to get a r/h one genuine ford Not realising this at the time. 2 weeks ago i decided that while it was all striped down i would replace the l/h side only to be told theres no more. Fortunately i hadnt removed it. I made a large repair section for the lower half of it.Ill try tonight to get some photos up of the area. Have you got the piece of foam in a bag hidden in the upper chassis arm. In you first photo above where youve paint red oxide there a rubber bung remove it and check inside. mine had it both sides and was wet. This is the cause of that area rotting from the inside out. and yours looks to be the same. Colin.
colingo wrote:Hi, have you tried talking to central panels about that section. That section i should think is as equally prone to rot and accident damage as the rest of the sections in that area. Leave the outer arch section in place for the time being because if you need to fabricate a section youll need a decent Datum.
Ok, i think ive found a source for your missing arch inner section and inner cills.email, info.lcs@gmx.com his name is Tim, also a member on here but not frequently.
When you think that sponge in a bag was installed in mk6 vehicles then continued through mk7 production does make you question the thinking.
Cheers, Colin.
sharpie75 wrote:colingo wrote:Hi, have you tried talking to central panels about that section. That section i should think is as equally prone to rot and accident damage as the rest of the sections in that area. Leave the outer arch section in place for the time being because if you need to fabricate a section youll need a decent Datum.
Cheers, Colin.
Cheers for the email address Colin, will look into. I've searched for them online but nothing came up.
Thanks Ned, Col is passing on his details to me. Thanks for reply.ned wrote:Try Tim on here dieselhead123 he makes several repair parts of these vans.
