No you don'tscas wrote:dont forget you need a big foppin hammer and big arms
karl wrote::roll:![]()
my way is heat them up an hit them with a drift and hammer works all the time
bambi mk 1 wrote:karl wrote::roll:![]()
Idiots guide to shoot yourself https://www.youtube.com/watch?v=TIKFmJXGz1M
NEVER EVER HEAT A BALLJIONT
karl wrote:bambi mk 1 wrote:karl wrote::roll:![]()
yes you have reminded me many times before
hgv ball joints get the same treatment![]()
not one has exploded yet
thanks karl
Nah..scas wrote:thats a good idea, still need a big hammer to put it in again
Airthies wrote:No you don'tscas wrote:dont forget you need a big foppin hammer and big arms![]()
Work smarter not harder![]()
..... A hammer may be required to get the tapers out the arms though. Just smack the outside edge of where the taper is directly opposite the arms and they'll usually just pop out.
Do the TRE's first so you can spin the strut to get a better angle at things.
Take out split pin and remove dummy hub shaft nut before removing wheel.
avromo wrote:Airthies wrote:No you don'tscas wrote:dont forget you need a big foppin hammer and big arms![]()
With this setup what are you winding out to create the downward pressure
