p1692 any one know what this code means
Postby Nedw99 » Fri May 08, 2020 12:56 pm
Any one know the cause and any possible fixes ? 2011 transit tipper 2.4 any help is appreciated thanks ned
Nedw99
Re: p1692 any one know what this code means
Postby Nedw99 » Fri May 08, 2020 12:59 pm
I dont know why it says 2.2 euro 5 , it's a 2.4 euro 4Image
Sent from my SM-G975F using Tapatalk
Nedw99
Postby Jim Archer » Fri May 08, 2020 3:10 pm
140PS? Turbo actuator sticking/jamming.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Nedw99 » Fri May 08, 2020 7:03 pm
Is that what p1692 normally means ? Thanks for the reply
Nedw99
Postby Nedw99 » Fri May 08, 2020 7:04 pm
And yh it is a 140 ps
Nedw99
Postby loot » Fri May 08, 2020 7:19 pm
The 130 and 140ps euro 4 both have a vnt and it is electronically actuated, there's is the black servo box mounted on the turbo rather than a vacuum actuator.
Anyway the code says wiring fault and that means exactly that, there is an earth or resistance fault detected.
You have 5 pins, 2 go to a motor and 3 go to a potentiometer, so the pcm can work out where the turbo is, that and it sees other data from map and maf to further determine and also from the egr.
Anyway, either the actuator is faulty or wiring /connector to it. Check the connector for signs of damage. You can plug and play another actuator to see if that solves it.
But, first clear any codes and see if it comes back.
Flat batteries etc can bring up random fault codes see.
Ids map here
loot
