Stumble wrote:Thanks
Its near on 200000 but drives ok otherwise
No idea about bleeding not tried that yet
But would that affect throttle response ?
andz327 wrote:Good news is lord knobby is getting bit auld nowadays and your van doesn't have dual mass flywheel ANDZ
Me getting aulder by the day tae mate it's fookin rubbishknobby1 wrote:andz327 wrote:Good news is lord knobby is getting bit auld nowadays and your van doesn't have dual mass flywheel ANDZ
I did say l didn't think it had one..! And yes, I'm gettin' auld.
no - its not slipping atmandz327 wrote:Good news is lord knobby is getting bit auld nowadays and your van doesn't have dual mass flywheel so clutch kit isnt to bad price wise bad news is the gearbox needs to come out, they can be bit temperamental to bleed and you could make it worse
Do the engine revs go up but you don't start moving when letting clutch up?
correct, as if the pedal isn't right up on the clutch switch - so far only breiflyandz327 wrote:Or doesn't the revs go up when throttle is pressed ....nothing happens ??
yes, some there, thinking of trying to put a return spring on, if I can find oneandz327 wrote:Any free play in clutch pedal??
Stumble wrote:So, is pressure bleeding effective ? like a using Gunstone kit Thanks
knobby1 wrote:Stumble wrote:So, is pressure bleeding effective ? like a using Gunstone kit Thanks
Easiest way to bleed the clutch is to connect the left front brake caliper bleed nipple to the slave cyl bleed nipple using a suitable tube, open both nipples and slowly pump the brake, this will back flush the clutch system.
LordKnobrot
Users browsing this forum: Google [Bot], TheCake
