Hi guys,
I'm usually ok at nutting out problems with this thing, but...
I have a 600k km old and well looked after 2008 2.4TDci, and have had to replace injectors, SCV/PRV, EGR etc for all the usual reasons (idle/FRP issues) over the years, but I'm a bit screwed up by this one.
It's been giving the usual surging idle, fluctuating rail pressures and noisy combustion in combination with the usual EGR fault codes issues (I use FORScan) so I have replaced the EGR (updated/water cooled) plus the SCV/PRV and also pressure sensor. Cleaned out the intake, cleaned the MAP and MAF and fitted a new fuel filter.
It now starts easily, but still has the combustion rattle and surging cold idle but the idle stabilises at operating temp. The fuel pressure at idle is very stable, but high at approx 10,000psi (where it should usually be 3500psi).
The odd thing is, the higher the engine revs, either driving or free revving, the closer together the actual vs desired pressured get. Once I hit around 2,500rpm, both actual and desired are around 20,000 psi... which seems about perfect to me.
I know we've all seen rail pressures bouncing all over the shop and massively high no matter the revs, but has anyone seen something this specific... high at idle but good at revs???
Cheers guys... Craig
PS... I've had the new SCV/PRV/Sensor for a couple years (I believe in being prepared) but can't recall where I bought them... may have been either Fleabay or TPUK.
