Front Grille Badges MK7
Postby TonyBrown1948 » Thu Jul 09, 2020 3:30 pm
Question from a non-mechanic, hope someone can help!! Need to change the two front grille badges on my MK7 transit campervan, ie the main Ford badge and the TDCI badge. Can anyone advise me if these badges just prise off the front of the plastic grille, or do I have to remove the grille and then remove any speed fasteners/nuts from the back of the badges? Hopefully I don't have to remove the grille! Thanks in advance.
TonyBrown1948
Re: Front Grille Badges MK7
Postby Cooter » Thu Jul 09, 2020 4:21 pm
The front Ford one (if genuine) will be self adhesive with two small pins on the rear that insert into little holes on the grill making lining a new one up an easy job. Old one should come off easily enough with a decent sized flat screwdriver.
Always smileying!
Cooter
Postby tilly » Thu Jul 09, 2020 6:39 pm
Ford should give you a free grill badge. Its a warranty item, due to a manufacturing defect. Got mine replaced two years ago, and mines an 07 reg.
Mk7, FWD 110ps GLX in Silver 2007
tilly
Postby madtheswine99 » Thu Jul 09, 2020 7:00 pm
tilly wrote:Ford should give you a free grill badge. Its a warranty item, due to a manufacturing defect. Got mine replaced two years ago, and mines an 07 reg.
Really, might have to enquire about this as mine is an 09.
madtheswine99
Postby MattD » Thu Jul 09, 2020 8:01 pm
The TDCI badge is very simple and just clips on. Mine was all faded and I replaced it with this one for £3.99
https://www.ebay.co.uk/itm/272375621176
MattD
Postby tilly » Fri Jul 10, 2020 12:06 am
You also get one free replacement key fob.... or, you used to.
tilly
Postby dethleffs » Mon Jul 13, 2020 6:43 pm
I got a free Ford oval badge on mine a few years ago. Seem to think it was a ‘get in quick offer’ but no harm in asking. As said TDCI badge from eBay.
One life, live it
dethleffs
Postby EJB » Mon Jul 13, 2020 7:14 pm
My 2009 Mk 7 (Burstner Motorhome) badge fell off at home a couple of weeks ago. I used stronger double sided tape to reattach it!
Must have been the hot weather in East Anglia!
EJB
Postby paulrichardson » Thu Aug 07, 2025 12:25 pm
Sorry to wake up an old thread but I'm confused with Grille Badge Removal.
I've just watched a You Tube video, the guy removed his Grille and there were two bolts behind it. He unscrewed these and the Badge came out.
I don't want to damage anything by attacking it with a screwdriver if it's bolted on.
What's the consensus on this one?
paulrichardson
Postby DanMK7uk » Thu Aug 07, 2025 8:16 pm
paulrichardson wrote:Sorry to wake up an old thread but I'm confused with Grille Badge Removal.
Mine was only stuck on. Originally. Prised it off
DanMK7uk
