2007 FWD, 2.2 SWB.
Had it about 3 months, few issues with ESP + Airbag lights which have been sorted. Reversing lights have now stopped, but got a bigger problem now.
Van drives fine, mostly pulls well, loaded and empty, no smoke usually. BUT, occasionally (Once every 20 mile trip or so), i'll change up a gear or push the throttle to accelerate, revs will hold, and there is no power at all. Even on the flat, foot to the floor vehicle speed stays contant but no RPM increase.
If I drop a cog, sometimes it clears with a cloud of smoke, sometimes the revs will stay flat for a more few seconds, then pick back up and will return to normal.
No DTCs or warning lights at all, I have Forscan and did a pilot learn last night which vastly improved the smoothness of the engine, but the power loss then happened twice on the drive in this morning.
I'm going to check and drain the fuel filter again later (There wasnt much in it when I did it about a month ago), but after that, thoughts?
