Hi guys,
My Mk7 2.4 turbo diesel (RWD) is experiencing starting issues.
It seems to mainly happen when the vehicle is hot, where it will crank but just not kick over. I will then wait around 1-2 hours, and it will start.
I did some research on this site, and it seems like issues starting when hot could be the Crank Angle Sensor?
I brought the vehicle to a Ford dealership who scanned it, and said the following codes were coming up:
P2539
Low pressure fuel system sensor circuit
Status 28 (not current DTC)
Fault type 00
Fault previously detected. Not currently present.
Diagnostic protocol - 14229
P0148
Fuel delivery error
Failure type 00
P0645
A/C clutch relay control circuit
Status 2F (current DTC)
Diagnostic port - 14229
Fault is currently present
I had a new genuine ford EGR valve (had loss of power low rpm, which fixed the issue), and fan speed resistor fitted around January 2020. New turbo and intercooler fitted shortly after.
However I explained to Ford when the turbo failed the engine revved so hard on its own, even though I took the key out, it stayed on reving for a little bit. They call this "run away", and said that could have damaged my engine or high pressure fuel pump.
Ford are saying they will need to inspect it, and are allowing 4 hours at $198 AUD/hour.
Has anyone had anything like this before, or have any suggestions on what it could be?
Thank you on advance!
Sent from my SM-N975F using Tapatalk
