most times when the ignition is turned on I have to reset th
Postby markbow » Sat Sep 19, 2020 9:26 am
I have a weird clicking noise which I think is the trip mileage resetting which it does back to 0
most times when the ignition is turned on I have to reset the radio code every morning first start I can do short runs and leave the van for two or three hours radio is fine until next morning but nine times out of 10 the trip mileage will reset
if I leave the ignition on after five minutes same thing will happen in the cluster will go blank no lights on cluster
as I've been trying to use forcecan to take tachograph off
many thanks in advance
Mark
Ford transit 08
115 T350 RWD
2402cc
EX traffic light maintenance
twin side doors
Ford transit mk7 08
115 T350 RWD
2402cc
LWB HITOP
markbow
Re: most times when the ignition is turned on I have to rese
Postby Airthies » Sat Sep 19, 2020 9:38 am
Depends on what van you've got but sounds like a typical flat front battery in a Mk7 that's got twin batteries.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby markbow » Sat Sep 19, 2020 10:07 am
Ford transit 08
115 T350 RWD
2402cc
Hi Airthies
thank you for the reply if it is a dodgy battery is it possible on just one
Ford transit 08
115 T350 RWD
2402cc
I'm also getting this code
code: P068A- ECM/PCM power relay de-energises to early
many thanks
Mark
twin side doors
Ford transit mk7 08
115 T350 RWD
2402cc
LWB HITOP
markbow
Postby Airthies » Sat Sep 19, 2020 10:46 am
Just disconnect front battery and connect positives together on the rear one. Will get you going but would recommend replacing the front one.
See what happens to the codes when you remove the dead battery from the system.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby markbow » Sat Sep 19, 2020 11:20 am
okay thanks I will try that later would that stop the ABS from showing on forscan as I really needs to do an ABS bleed
many thanks
Mark
twin side doors
Ford transit mk7 08
115 T350 RWD
2402cc
LWB HITOP
markbow
Postby markbow » Sat Sep 19, 2020 12:51 pm
Hi Airthies
just curious what makes you say the front battery
many thanks
Mark
twin side doors
Ford transit mk7 08
115 T350 RWD
2402cc
LWB HITOP
markbow
Postby blue estate » Sat Sep 19, 2020 1:01 pm
markbow wrote:Hi Airthies
many thanks
Mark
Because that one serves the ecu’s locking , dash, radio and BCM module
Low battery voltage causes these to go hay wire
Sent from my truck some where
72plt MG 5 ev estate Battery car
blue estate
Postby Airthies » Sat Sep 19, 2020 5:44 pm
many thanks
Mark
Wot ee sed.
And cause it's a well documented phenomenon (doo doo doo doot doot, in a Muppets stylee)
V86+patch
V86.04
X-Prog
C81
Airthies
Postby markbow » Sat Sep 19, 2020 7:12 pm
Hi Airthies
thank you very much you was 100 percent right
just put the battery tester on it back one 100% front one nothing
I know the back one looks after the starter motor as I have had to pull it off many times
when star motor keeps spinning there's always a spanner in the little thing before the cupholder
many thanks for all your help
Mark :D :D :D
twin side doors
Ford transit mk7 08
115 T350 RWD
2402cc
LWB HITOP
markbow
