LowSlungDub wrote:Hello! New to Transits!
I've searched the forum but not found any fix for the issue I'm having;
At around 1600-2000RPM in 4th/5th I get a quote violent Judder, like the engine is rocking. It only does it when I'm feathering the throttle and starts off gentle and slowly gets worse until I have to let off the pedal and then reapply power which solves it for a few mins.
I'd love to get to the bottom of this, it's only done 120k and been very well looked after!
I have read many things on driveshafts, egr, dirty inlet, etc but would like to know what to check first!
Hope I've posted this in the right place!
LowSlungDub wrote:Knobrot, you're the reason I joined, you came up in a few searches saying driveshafts and it feels as if there's slack somewhere like a driveshaft, I wouldn't think the DMF is faulty as it drives really well and pulls of better than most things I've driven. How would I go about checking the driveshafts without taking them out? I'm used to VW stuff which is all I've ever owned in 15 years of driving.
It's fine at any other revs in any other gear. It's not got worse or better with an EGR clean, new fuel filters, inlet clean etc. It definitely feels more mechanical. I guess I'll check the shafts and then the DMF just to be sure.
Punto443 wrote:I'd be looking at the fuel rail pressure on live data while recreating the affected parameters
Is there any fluctuations (hunting) while at idle?
Users browsing this forum: AFCFanChris, Google Adsense [Bot], Jackleggett
