Hi
Just new to the forum, need help
I have a transit mk7 2.2 euro 5 fwd, I just had a refurbished engine installed, the cog light came on, checked fault code P0341, replaced cam sensor fault still there, changed crank sensor, fault still there, took it to an auto electrician, got the all-clear, got the timing checked everything fine, the cog light on was very intermittent, the engine is hunting when you try and give it revs, I am now in limp mode due to P2463 needing a regen, if I had any hair left I would be pulling it out lol
