No the bottles are not in ml they are in cm which is not the same. The measurements are meaningless.loot wrote:So tonight I did new learns then fitted new green o rings and did a leak off test. Which I had to mess with the Chinese kit to get it to seal and I drilled vent holes in the caps.
Anyway I don't know if the measurements on the bottles are accurate or actually mean ml, if they are then I'm screwed.
Airthies wrote:No the bottles are not in ml they are in cm which is not the same. The measurements are meaningless.loot wrote:So tonight I did new learns then fitted new green o rings and did a leak off test. Which I had to mess with the Chinese kit to get it to seal and I drilled vent holes in the caps.
davyjcb wrote:Leave the cat as is, Go to the next box and drill a very small hole in the very base of the box at the lowest point to see if any residue drips out if none then a tack weld will cover it.
If you hold your hand over the exhaust at tick over it curtails the engine breathing, more exhaust gas is drawn through the egr the fuel air mixture goes way way too rich that probably what's giving you the soot when you remove your hand
davyjcb wrote:Yes but...dont rev the fook out of her or your new turbo won't be new for very long as you need a little back pressure in the system to stop the turbo overspooling
Users browsing this forum: M3Stig
