by arrolman » Fri Nov 20, 2020 1:55 pm
Had an ongoing intermittent fault for the past year thats really beginning to piss me off. When driving the oil warning light will come on and the van will lose power, as though the turbo switches off, happens for a second or two then goes back to normal. However, sometimes the engine cuts out and or appears too. Driving to work this morning it happened and noticed the lights dimmed then came back on full once oil light went off. I have changed the prv/scv(Genuine) full update and all learns in past 6 months. Gets serviced every 6 months on the dot. EGR deleted, inlet manifold cleaned, all sensors checked. Only fault codes I sometimes get are turbo underboost/turbo overboost, battery de-energised too soon. Codes only appear now and again, not every time. Anyone got any ideas of where to look? Its been in garage 3 times, as usual it never happens when they have it so can't replicate it or get an idea of when/how its happening. Have also checked all ECU connections etc and all good. Can run for a week not doing it then will do it 3 times in a journey the next. Does it if feet are on pedals or off, I'm stumped. MK7 2.4 140
07" T330 2.4 Tdci RWD
