Hi all.
Driving along the A55 last night and my wipers stopped mid flow. Also the blower.
I pulled over and checked fuses. No problem found. I did notice the dash symbols were also off. But when key in 2nd position they might flash briefly when a large enough truck went by to rock the van.
Also. If I keep turning the key back and forth they might flash.
They did come back on for a while then stopped again. So we abandoned our camping trip and made for home.
At the moment they are off but occasionally I might get a second of blower noise etc then off again .
When I turn the key to/from pos2 I always here the click from somewhere under the fuse box so assumed the ignition switch is switching?
I have checked wires. Wobbled and shaken Em. Nothing . Can't see anything obvious. Had rear lights interior lights off. Ignition unplugged and re pluged. No different.
I have searched the forum and found similar issues. One was a relay but no idea which. one was posibly ignition? So I have ordered a new barrel and connector anyway just in case.
Any advice would be great please.
Many thanks
2006 mk6 high top 2.4 turbo medium body 115 T350
