My van is a 2004 Mk 6, petrol/LPG, 2.3 ltr DOHC engine.
I have a problem with the airbag light permanently on, although a scanner shows no fault or fault codes.
What happened was this: (please excuse the following lengthy explanation):
I took out the instrument cluster to clean the circuit board, as a few digits were not showing on the trip recorder. When I took the cowl off the ignition I noticed a key taped to the ignition barrel, which I took off thinking it was a spare. After that I couldn't start the engine and I got a fault code on the immobiliser saying "key not recognised". Thanks to advice given on here, I put back the key on the barrel and the engine started ok,I didn't know the key had a chip which the immobiliser had to read.
So far so good - the engine ran and the trip recorder was fixed. The problem then was that the airbag light will not go out. I checked the wiring and it seemed ok. I went to a local garage and they could see no fault with their scanner and were mystified.
The other weird thing was that the beeper which sounds when you open the door with the headlights on suddenly started working again, after being non-functioning for maybe two years.
As far as the airbag goes, the mechanic suggested I simply discoonect the warning light at the circuit board, but I am reluctant to do this if a proper explanation can be found.
Any ideas, anyone?
