Panic_state wrote:Hi im just about to replace my injectors and I've got to code them in using forscan however looking at the diagram its a little confusing as to what firing order it goes in now I understand that from the front Cylinder 1-4 left to right but I cannot find a definitive order that I need to code them in as in firing order to what cylinder its a euro 5 some say 1423 others say 1324 other 1432 some off euro4 aswell its all a little confusing ive looked everywhere the Internet ford diagrams etc still no clue ...
Panic_state wrote:Thank you both very much really appreciate the help i was stressing i wouldnt get them in the right order
So when I code them just so I get it right
1 cylinder = injector 1
2 cylinder = injector 4
3 cylinder = injector 3
4 cylinder= injector 2
So when I code them in I see there is a box you write them in number 1 -4 am I coding them in to each cylinder or firing order christ it makes my brain hurt
dymondaudio wrote:Panic_state wrote:Thank you both very much really appreciate the help i was stressing i wouldnt get them in the right order
Please could someone clarify as I've just fitted new injectors, I have coded them and done the pump and learns (which completed) but it is running rough and I wonder if this is my issue.
mine is a RWD so looking at the front of the engine (one being the closest cylinder to you) I coded them as follows:
Cylinder 1 (closest to me) = injector 1 value
Cylinder 2 = injector 2 value
Cylinder 3 = injector 3 value
Cylinder 4 (bulkhead) = injector 4 value
But I'm now thinking this is wrong and explains why it's running like a bag of nails, any advice appreciated.
knobby1 wrote:dymondaudio wrote:Panic_state wrote:Thank you both very much really appreciate the help i was stressing i wouldnt get them in the right order
You say you've done the "Pump" learns....but have you done the "pilot and injector" learns...?? If not it will never run correctly. Forscan is pretty clear as to which injector is which and which cylinder is which.
Were the SCV and PRV also replaced..??
andz327 wrote:To code in with forscan it's not the actual firing order, the diagram is simple as it shows 1234 so it gets coded 1234
4 being as shown at the flywheel end
front to back RWD 1234
left to right FWD 1234
Sent from my SM-G975F using Tapatalk
andz327 wrote:What was original problem???
andz327 wrote:Any joy ??
